New Owner - 2 Issues
EZMoney
SW Michigan
Howdy! Just bought my first 4 days ago- 2017 Range Rover Evoque! I have a “Battery Low” warning- And only blows cold air- Where can I find these threads? I was told that if a certified shop doesn’t replace the battery, it will brick the vehicle... it has 92K on it, so where would I find out to see if the climate control issue is covered under warranty? Hopefully, I won’t be here too often!
Welcome to the forum. Check the Range Rover Section.
Rover Range
Texas
The battery needs to be replaced and the "battery counter" reset.
On the AC complaint. May be a temperature blend door calibration issue.
A562NV
