When the voss connector on my front block was leaking it was super easy to spot with soapy water from a spray bottle. I just had to snug it a little and that was it. Hopefully yours is the same.
Wow! This is why I love this forum! Although, I feel like a complete slacker in that I don't have more data points to populate the graph!I agree, the RR seems to be the culprit, I just plotted the data in Excel and see this:
I definitely think that the RR is pulling down the RF and the LR, here are the height changes vs time:
It looks like after three hours the rear is already dropping but only by 1/8".
Checking that the RR pipe and connection to the valve is going to be interesting, so things it could be:
- Airspring
- Pipe fitting to airspring (o'ring?)
- Pipe
- Pipe to rear valve (o'ring?)
- Leak internal to the rear valve (so venting to the gallery), does the gallery pressure rise overnight)
Keep us posted and good luck with the weather and not freezing!
