iSurfvilano
Just a PSA. If you install the heavy duty axles from RCV, be sure to cut the lower sway link bolt on the front driver's side as it'll rub and eventually puncture the CV boot when at full articulation. I noticed this as the suspension was fully extended and thank God I did. The only ****** part is that you'll have to cut the link off when it's time to replace.... But meh... Worth it.
