New Recall Alert : Fuel System
mm3846
LI, NY
Thanks for the information. So I have not talked with the service rep yet but I'm wondering if they play the "the recall could not have caused the filler neck problem". Also you say that a leaking fuel flange(I believe this is the exact recall item?) caused the purge valve to overwork and it fails. Wonder if that new purge valve should also be covered under the recall fix?
So in the video I posted the smoke is coming out of the filler neck area and you think that is happening because of a bad purge valve? Is there any long term damage I need to worry about now after I replace the purge valve? She has about 105k miles on her and I've been wondering if its time to trade her in. The oil leak the tech pointed out in the video also worries me errrr. I'd love to keep the LR4 as long as possible but don't want to throw money away if there is no hope.
I have not seen the P0442 code yet BUT my LR4 does have a P0456 code atm.
Again thank you for taking the time and posting this. I'll check out your thread.
P0456 is another EVAP leak code. No damage, but it’s possible that the charcoal canister is saturated to the point where you’ll start eating purge valves every so often until it’s replaced. Mine might be, I’ll know if I get this problem again.
The smoke comes out of a vent at the filler neck, that’s how it is supposed to work. The smoke isn’t going anywhere bc there isn’t a leak, and you can’t test the purge valve operation without an expensive computer system… even the GAP tool we all use doesn’t do it.
There’s zero chance you’ll be able to get the dealer in the hook for this stuff. The EVAP system is just one big chain of parts that depend on each other, so if something fails there’s usually another piece trying to compensate. Is what it is. I had to replace the whole system on Silverado a few gears ago.
Balto
AZ
Did you have the "Can only put 17 gallons of gas into the tank" issue like others have mentioned?
mm3846
LI, NY
I had that since I bought the truck, but that got fixed when the recall was done. The purge valve can definitely affect that, since the EVAP system will push fumes out of the fuel filler if it’s not working correctly and shut the fuel pump off early.
Balto
AZ
Just got a call from the dealer tech advisor. Looks like they want to replace the filler neck because it is causing the EVAP leak. Said he doesn't believe the recall fix could damage it but I said yes it could and multiple people have had this happen so he is going to talk with his manager tomorrow about it. Wants like $1,500 for the filler neck ATM.
Also the oil leak seems to be the Timing Chain Seals? Said its leaking onto the alternator but hasn't caused any damage at this point. Wants $2,714.98+Tax to fix the seals.
mm3846
LI, NY
I’ve heard of others having issue with the filler neck. That front cover leak will ruin the alternator eventually. I have no idea on pricing, I can’t afford to send my truck to the dealer.. lol.
ftillier
Portland, OR, USA
From what I understand, they must disconnect the filler neck in order to drop the tank for the recall. I thought I'd seen @Rover Range confirm that in another thread.
Balto
AZ
Well they still won't repair the filler neck! Saying the recall could not have done any damage and that its a "age" issue. The person I have been talking with is just a tech advisor and it was his manager that made the call. I requested that the manager call me and to provide proof of this problem happening to others.
Can anyone with the Filler Neck issue please provide me with any information you have..anything at all would be great. Maybe the service person you worked with and contact info? or paperwork or really anything. Thanks
mm3846
LI, NY
Honestly the truck has 100k on it, unless you have a good history with the dealer I doubt they’d cover it for you. I still think it’s the purge valve.
petrhick
