Ruski
Hello I’m having issues with my rover so I’ve been getting a suspension fault message, the truck would stay in normal height so it was drivable and it was like this for more than a week I would start the truck, about 30 seconds later I’d get suspension fault but not all the time sometimes id get the message like 10 minutes after when I’m driving but then one night I parked it in normal height didn’t hear any hissing noise(it’s really quiet when I get home from work a little too quiet but I’m more than sure I would’ve heard a leak if it was leaking) and in the morning it was in access height not fully aired out, I’ve seen one fully aired out and the wheels were tucked into the wheel wells, mines is not like that it’s in access height and I can’t get it out of access height because once I start the truck about 5 seconds after starting it I hear the compressor come on for sometimes 10 seconds sometimes 25 seconds then the compressor shuts off and I get suspension fault. I’ve tried selecting normal height before I get the suspension fault but nothing happens, it does this every time I start the truck. If there was a leak in one of the bags wouldn’t it drop all the way down not just to access height? Also if the compressor gave out it wouldn’t start up at all would it? I was thinking maybe the valves? I tried removing the front valve block, when I started loosening the air hose I could hear air starting to come out and tightened it back up, I didn’t want to fully air out the bags so I just put it back together. All fuses are good, I’ve heard of jumping the relay but I’m too scared to try that I read I could possibly mess up wiring. Any help would be appreciated
