Kyle Imes
hi all, i bought a land rover a couple months ago and it needed head gaskets. it has 162,000 miles on it with the 4.4 engine. I tore the engine apart and replaced the head gaskets along with the secondary chain tensioner. after getting it all back together it threw a cam out of correlation code so i took it all back apart and re-timed the whole thing. after putting it back together the second time it ran great after I connected the maf sensor and changed the egr. now it runs great but only when under load, i can go uphill or let it idle in the driveway for hours with no change, but when i star coasting downhill it seems to go into limp mode and has no throttle response. i can push the pedal to the floor and it will shift down but nothing from the engine. it throws three codes when this happens, im not sure of the p0 code but it says "internal torque calculation performance" twice and a third code says forced engine shutdown. i am absolutely losing my mind trying to figure this out and nothing has worked so far. i added transmission fluid and changed the cam sensors but at this point im just stuck. any help would be greatly appreciated.
