2005 LR3 suspension issue
Ozark_BillHilly
Bolivar missouri
Have a 2005 LR3 with suspension issues, getting the "transmission fault, traction reduced" error, also "special programs unavailable", my suspension is stuck down on bumpers.
I have the IID Gap Tool, still very new to using it however
I have replaced the compressor with a new Hitachi one, I am getting nothing, no humming or anything, relay is new with part
I have tried utilizing the GAP tool to do a calibration on suspension, but when I go into the settings and try to perform this it says error failed?
I have replaced the terrain selection module and still getting same issues, cannot lift vehicle or select off road selections. I can switch into 4x4 low and switch back to 4x4 high with no issues.
I have performed a "hard reset" with no luck
I am getting a codes "U0132-87 "lost communication with ride level control module
"C1A09-1C" Pressure Sensor signal
"C1A11-65" Pressure increases when system inactive
"C1A13-64" Pressure does not decrease when venting gallery
"C1A36-01" Exhaust Valve - General Failure information
I have checked every fuse in the fuse area, nothing was blown and seems fine by visual
I literally do not know where to go with this, I feel like I am just throwing money at an electrical gremlin
Thanks for any help
See less
m_lars
Utah
Try jacking up the vehicle off the bump stops and see if it will pump up for you. Last time mine dropped I had to do that to get it to raise. I had different codes than you mention, but it’s definitely cheap, easy and a common issue. You won’t be able to calibrate until you’re sitting at normal ride height.
Was your out-going compressor a Hitachi as well? Or an AMK?
ILR4
