2011 L322 EAS nightmare: C1A03-78, C1A13-64, now U3000-55 after AMK RLM flash
KimberlyB
Dyersburg, TN
I’m hoping someone here has seen this exact combination before because I feel like I’m chasing three separate suspension problems that may be interacting.
Vehicle is a 2011 Range Rover HSE L322, 5.0 NA, VIN SALMF1D4XBA358201, with an AMK compressor and GAP IIDTool.
This originally started as an EAS problem. The suspension controls in the truck stopped working correctly and diagnosis kept pointing toward the left front height sensor. I eventually removed that sensor and the suspension diagnosis got put on hold for a while. More recently I installed a new LF height sensor and started working through the system again.
The main recurring height-sensor fault has been:
C1A03-78 - Front left height sensor - Mechanical failure - alignment or adjustment is incorrect
The LF sensor has a healthy 4.91 V supply, and when I manually move the arm GAP sees the output sweep from about 0.20 V to 4.70 V, so the sensor circuit is definitely alive and the RLM is seeing it. The sensor arm is physically connected and moves. The LF and RF calculated ride heights have also matched within a few millimeters at times, even though the LF raw voltage has looked very different from the RF raw voltage.
At one point, while the truck was sitting with the charger connected, the suspension raised itself off the bump stops. So we know the compressor can run, the relay and power circuit can function and the vehicle can physically raise.
At normal-ish height I saw approximately:
LF calculated height: -0.003 to -0.006 m
RF calculated height: -0.003 to -0.006 m
LF raw sensor: as high as 4.70 V
RF raw sensor: around 1.57 V
That LF raw voltage being so close to the top of its range obviously still concerns me.
The other recurring fault has been:
C1A13-64 - Pressure does not decrease when venting gallery - Signal plausibility failure
This one became very reproducible. After restarting the vehicle, the suspension controls would come back. If I pressed UP, the dash would say “Raising” for about 3 seconds, then I would get a beep, all the suspension-control lights would go out and the height request would abort.
I recorded GAP live values during one of these events. The important part was that the system was not simply dead.
Before the command, gallery pressure was around 400-418 kPa. During the command, the compressor ran at around 13.1-13.2 V, the reservoir valve opened and gallery pressure climbed to roughly 1,160-1,180 kPa. The RLM then commanded the exhaust valve open, GAP showed exhaust valve current and the pressure later dropped back down to around 400 kPa.
So the compressor can build pressure and the RLM is commanding the exhaust valve, but the RLM still decides the pressure did not decrease in the expected way and sets C1A13-64.
The strange part is that the truck has also sometimes behaved like it thinks it is already in Off-Road height, even when the calculated front heights are essentially around zero.
Because this is an AMK compressor and my VIN is within the range of the JLR bulletin for C1A13-64, I checked the RLM firmware using GAP. It showed:
Actual firmware: AMK Compressor
The old RLM strategy was:
BH42-14D394-AB
GAP showed an available update to:
BH42-14D394-AC
I flashed the RLM using GAP’s AMK Compressor flash routine. The flash completed, GAP instructed me to start the engine, stop it and restart it. ECU Info afterward confirmed:
Strategy current: BH42-14D394-AC
Status: Up-to-date
Immediately after that, things got weirder.
The RLM then began setting:
U3000-55 - Control module - System programming failure - is not configured
At first I thought it might just be a stored programming fault from the flash, but it is not.
I cleared all RLM faults and rescanned without touching any suspension controls. U3000-55 came back immediately.
I also ran GAP’s Vehicle Reset under Service Test / All ECUs. After the reset, U3000-55 again returned immediately.
One recent sequence was:
09:16:22 - U3000-55 - not configured
09:16:25 - C1A03-78 - LF height sensor alignment/adjustment incorrect
So U3000 appears first, then the height sensor fault follows a few seconds later.
Since the flash, GAP’s Service/Test suspension functions have also become completely non-responsive. The menus open, but pressing the raise/lower/Test Valve controls does absolutely nothing. No compressor, no valve activity, no height change. The truck is now back down on its bump stops.
Before the U3000 issue, GAP Service/Test commands had worked in the past.
I have also seen C1A13-64 return after the AMK software update, so I do not believe the firmware update alone solved the venting fault.
For hardware, I already have rebuild kits for the suspension valve blocks, O-rings, compressor O-rings and new desiccant. I’m also looking closely at the AMK compressor exhaust valve, dryer/desiccant and exhaust/silencer path, because I’ve found several C1A13-64 cases where the exhaust solenoid, dryer restriction or clogged exhaust path turned out to be the actual cause.
What I’m trying to figure out now is:
  • Has anyone had U3000-55 “not configured” appear immediately after an IIDTool AMK RLM flash?
  • Does GAP’s AMK flash routine fully perform the JLR “Configure Existing Module - Ride Level Control Module” procedure, or does that still require SDD?
  • Can a failed or incomplete ride-height calibration cause U3000-55 and completely disable GAP Service/Test output?
  • Is there a way in IIDTool to force the RLM back into Customer Mode / normal EAS mode if it has been left in a programming or build state?
  • For those who have had C1A13-64 with an AMK compressor, did your actual fix end up being the compressor exhaust valve/dryer/silencer, the center/reservoir valve block, another valve block or something else?
  • For C1A03-78 after replacing the LF sensor, did you find the cause was arm orientation, bracket geometry, an over-center linkage or simply calibration?
At this point I’m trying very hard not to throw parts at it. We’ve already proven the compressor can make substantial pressure and physically raise the truck. I’d like to get the U3000-55/configuration problem sorted first, then deal with the LF sensor fault and finally retest the C1A13 venting problem with a properly functioning RLM.
Any experience with this exact combination would be hugely appreciated.
Sideshow76
SLC, UT
I'm having this exact problem and now just going to do a coil spring conversion. Did you ever find a solution?
ILR4
