2013 LR4: Click, quarter crank, nothing..."lost communication with TCM"
Wtx_LR4
Texas
Hi there,
I'm sorry if this has been discussed, but I've searched for days and can't seem to find anything.
I'm doing my buddy who is overseas a favor and trying to get his 2013 LR4 going while he's away.
Backstory: His neighbor who was supposed to start/drive it a few times a month forgot and let the battery die. They tried to charge the battery, but no luck. They bought a new battery, but same issue.
I agreed to take a look at it since I'm semi-knowledgable with vehicles... never worked on an LR though.
I hooked my jump pack up to it and got it started. I went to test drive it, but it wouldn't shift out of park. I figured out the manual gear release, but got nervous when I noticed it wasn't shifting out of first.
When trying to start it with only the new battery, it would click, crank ~1/4 turn, then stop. The dash lights would stay on.
I scanned it with a iCarsoft LR V3.O and got the following codes:
ECM Faults (7):
P0102-00
P010C-00
P0073-00
U0101-00
U0402-83
U0402-82
U0402-64
ABS FAULTS (1):
U0101-00
IPC FAULTS (1):
U0101-00
BCM FAULTS (2)
U0101-00
U200D-14
RLM FAULTS (1):
U0101-00
PBM FAULTS (1):
U0101-00
TCCM FAULTS (1)
U0101-00
My main concern is regarding the "lost communication with TCM" faults, but I'm not sure where to go from here.
Any advice would be greatly appreciated.
Thanks!
ftillier
Supporting Member
Supporting Member
Portland, OR, USA
Lost communication is often a side effect related to insufficient voltage from the dead battery. Odd that it would persist with a new battery, did they get the right kind? If it starts with the jump pack but not without then it's probably still the battery.
itsaguything
Manotick, On, Canada
As ftillier implies. "New battery" are rarely fully charged. Fully charge the battery before installation. If it doesn't read at least 12.6 v after a wait time of 6 hours after charging, that battery is done.
ILR4
