2014 Land Rover LR4, suspension faults after compressor and valve block work
shady090
Florida USA
I bought my 2014 LR4 a couple months ago and brought it to an independent Land Rover shop to address random suspension faults.
While it was there, they replaced the air suspension compressor. The one removed was apparently a cheap aftermarket (Chinese knockoff) unit. The first “new” compressor they installed malfunctioned, so they dug deeper and found water inside one of the valve blocks. Because of that, they replaced all three valve blocks.
After replacing the valve blocks, they installed a second compressor and felt confident it was fixed. I picked the vehicle up and drove it home with no issues. The next day, while idling in a parking lot, I noticed the suspension adjusting itself and a dash message came up like “Adjust ride height if clear of obstacles.” After that, the behavior got worse and eventually turned into faults.
Luckily I recently picked up a GAP IIDTool (IID4), so I scanned it. Now I’m repeatedly getting the dash warnings and the same related faults in the tool (screenshots below).
I messaged the mechanic with the fault info. He said to bring it back and they’ll replace the compressor again under warranty, assuming the compressor itself is bad. The part that has me confused is the water they found in the system. If moisture contamination is still present somewhere (lines, dryer, reservoir, etc), it seems like that could keep causing problems and possibly take out compressors or valve components again.
One other detail: the compressor firmware shown in the GAP tool indicates Hitachi. I sent that screenshot to the mechanic and he replied:
“Yeah I know, the system will not allow for the AMK set up… Land Rover removed the AMK programming…”
At this point I’m looking for ideas on what else to check or investigate before I can get it back to the shop (it’s about an hour away, so I’ll likely be taking it in next week).
Dash messages and GAP tool results below:
1. Reselect Suspension Height If Clear of Obstacle
2. Suspension Fault ... etc
I get it home hook up the tool and get the following:
Fault Lists:
VIN SALAG2V67EA730295
Model L319 - LR4 2014
Vehicle scanned on Feb 7, 2026 4:43:17 PM
IIDControl 4.3.0 Build 200 Android - IIDTool BT V4.0 B0434
ABS-Brake Module
U0421-68 - Invalid data received from ride level control module - Algorithm based failure - event information (28)
( on 07-02-2026 15:44:26 at 96948 mi )
BCM-Body Control
U0241-00 - Lost communication with the headlamp control module A (2E)
( on 07-02-2026 13:18:20 at 96947 mi )
FCDIM-Front Control
B1D21-13 - Remote control switch - General electrical failure - circuit open (28)
( on 07-02-2026 12:51:47 at 96946 mi )
HVAC-Ventilation
B13C2-86 - Windshield misting sensor - Bus signal/message failure - signal is invalid (2F)
( on 07-02-2026 12:48:59 at 96946 mi )
B13C2-96 - Windshield misting sensor - Component failure - internal failure (2F)
IPC-Instrument Pack
U0102-00 - Lost communication with transfer case control module (2F)
( on 07-02-2026 13:16:35 at 96947 mi )
PCM-Engine Petrol V6SC
P0483-36 - Fan performance - Frequency modulation/pulse width modulation failure - signal frequency is too low (6C)
( on 07-02-2026 12:50:38 at 96946 mi )
RLM-Suspension
( on 07-02-2026 12:49:05 at 96946 mi )
C1A06-92 - Rear right height sensor - Component failure - performance or incorrect operation (2E)
ECU info:
VIN: SALAG2V67EA730295
Vehicle scanned on 2026/02/07 16:59:36
Using IIDTool BT V4.0 B0434
AAM-Audio Amplifier
No update found
Assembly (F113) = EW93-19C164-AB
Calibration (F124) = EH22-14C527-DA
Hardware (F111) = EW93-14C524-AB
Serial = 0E2559227
Strategy (F188) = EW93-14C526-AB
ABS-Brake Module
No data from ECU
ACM-Audio System
Latest Version
Assembly () = Unknown
= BF6N-14C044-MAJ
Assembly (F113) = CF6N-18C815-JJ
Calibration (F124) = CH22-14C045-BJ
Hardware (F111) = CF6N-14C230-JD
Serial = 000040588863
Signal (F120) = CF6N-14C044-KAJ
Strategy (F122) = BF6N-14C044-RAT
Strategy (F188) = CF6N-14C044-NAG
ATCM-Terrain Response
No data from ECU
BCM-Body Control
No update found
Assembly (F113) = EH22-14F041-AE
Calibration (F124) = EH22-14C185-AB
Hardware (F111) = EH22-14C256-AC
Serial = 3254619922
Signal (F108) = EH22-14C408-AA
Steering Column Limits = 1FFFFF1F
Strategy (F188) = EH22-14C184-AD
TPMS Spare Wheel = 00000000
TPMS Wheel 1 = 0FF68C1F
TPMS Wheel 2 = 0FF68BD3
TPMS Wheel 3 = 0FF68BE0
TPMS Wheel 4 = 0FF68BCA
VIN = SALAG2V67EA730295
DDM-Driver Door
Update available
Assembly (F113) = BJ32-14D618-AC -> AH22-14B531-AG
Calibration (F124) = EH22-14C065-AA -> AH22-14C065-DD
Hardware (F191) = BJ32-14C235-AA
Serial = YC007NG10927A
Signal (F120) = BH42-14C321-AA -> AH22-14C321-CC
Strategy (F122) = BJ32-14C068-AC -> AH22-14C068-AF
Strategy (F188) = BJ32-14C064-AC -> AH22-14C064-AD
FCDIM-Front Control
Update available
= EH22-14C621-CD
Assembly (F113) = EH22-10E889-CE = Up-to-date
Calibration (F124) = EH22-14C061-CE -> EH22-14C061-CF
Hardware (F111) = EH22-14C234-CC
Serial = 000004278024
Signal (F120) = EH52-14C395-AB = Up-to-date
Strategy (F188) = EH22-14C060-CE -> EH22-14C060-CF
FCIM-HVAC Buttons
Latest Version
Assembly (F113) = CH22-19E900-NB
Calibration (F124) = CH22-14D072-AA
Calibration (F125) = Base
Hardware (F111) = CH22-14D069-NB
Serial = 140715083101
Signal (F120) = AH22-14D070-AB
Strategy (F188) = CH22-14D071-AA
FCIMB-Audio Buttons
Latest Version
Assembly (F113) = EH22-18C858-AB
Calibration (F124) = CH22-14C536-AB
Hardware (F111) = CH22-14C533-BB
Serial = 140708110202
Signal (F120) = EH22-14C534-AB
Strategy (F188) = EH22-14C535-AB
GSM-Gear Shift
No data from ECU
GWM-Gateway module
No update found
Assembly (F113) = EH22-14F681-AE
Calibration (F124) = EH22-14F531-AG
Hardware (F111) = EH22-14F528-AA
Serial = 0000000002070262
Signal (F108) = EH22-14F529-AB
Strategy (F188) = EH22-14F530-AG
HCM-Headlamp
No data from ECU
HCMB-Headlamp
No data from ECU
HVAC-Ventilation
No data from ECU
IPC-Instrument Pack
No data from ECU
IPMB-Camera
No data from ECU
KVM-Keyless
No update found
Assembly (F113) = DPLA-19H440-BD
Calibration (F124) = AH22-14C105-AL
Hardware (F111) = DPLA-14C250-BA
Serial = 3301730119
Signal (F108) = CPLA-14C430-AC
Strategy (F188) = DPLA-14C104-AD
OCS-Occupancy Sensor
No data from ECU
PAM-Parking Aid
No data from ECU
PBM-Parking Brake
No data from ECU
No data from ECU
PDM-Passenger Door
No data from ECU
RCM-Airbag
No data from ECU
RLM-Suspension
No data from ECU
SASM-Steering Angle
No data from ECU
SODL-Left Side Object
No data from ECU
SODR-Right Side Object
No data from ECU
SRM-Satellite Radio
No update found
Assembly (F113) = DPLA-14C740-AA
Calibration (F124) = DPLA-14C342-AA
Hardware (F111) = CH22-14C340-BC
Serial = 141564142000
Strategy (F188) = DPLA-14C341-AA
TCM-Transmission 8spd
No data from ECU
TEL-Cell Phone
No update found
shady090
Florida USA
Quick update with the new faults I’m seeing on the GAP tool, in case they help narrow this down.
At 96,946 miles (engine idling around 616 to 626 RPM, charging at 14.2V), I pulled the following additional codes:
FCDIM (Front Control)
B1D21-13: Remote control switch, general electrical failure, circuit open (logged 07-02-2026 12:51:47)
RLM (Suspension module)
U0102-00: Lost communication with transfer case control module (logged 07-02-2026 12:49:06)
IPC (Instrument Pack)
U0102-00: Lost communication with transfer case control module (logged 07-02-2026 12:49:00)
Update 2:
ftillier
Supporting Member
Supporting Member
Portland, OR, USA
Gap IID tool can update the firmware to AMK, that should be the first thing. Second thing is your mechanic sounds a bit shady.
shady090
Florida USA
Because I am a complete novice. Would you mind telling me the appropriate procedure for doing this?
ftillier
Supporting Member
Supporting Member
Portland, OR, USA
I don't remember exactly where, but I remember stumbling across it when I was poking around the app. I still have a Hitachi compressor so never had to run the procedure.
shady090
Florida USA
Btw earlier you mentioned the mechanic seemed shady. What was it that I mentioned that gave you that impression? Just curious if there is something I am missing. The shop is fairly new, and they do nothing but land rover, infact their shop name is based on land rover. They have a bunch of 5 star rating etc, but only started about a year ago. They have been very communicative.
I am not offended or anything by your comment to be clear, I am just a bit naive to all of this stuff and just trying to understand incase I am blind and missing something.
powershift
Nevada
Yeah, I've been bit by ****** "Land Rover" independents which includes a "Land Rover certified mechanic". Its all bs, they have some high school kids in there doing the work. Out front they park land rovers, land rover this, land rover that inside. Lots of shams out there.
ftillier
Supporting Member
Supporting Member
Portland, OR, USA
Telling you that you can't update firmware to AMK is wrong. It's also suspect that you would have had water in your air lines. To me it sounds like they were trying the parts cannon approach with a veneer of supposed expertise
Waisalima
