2020 Range Rover Sport Hse - Crank but no Start, after accident , fuel pump not working
wannapreg
Ghana
L494 MY2020 Accident
This car was involved in accident and the airbags got deployed, now Engine cranks but won't start, when starter fluid was sprayed into the intake, car runs and die, now the fuel pump does not come on.
Car has B1193-00 RCM - Crash event storage - Full and locked, and other related deployed airbags and seat belts codes as well. I managed to use autel to perform crash reset, in the event that the system will reset and get the car to start but it did not, when i look at the live data for the crash event, it's now NO(false ) but car wont crank, and also i can still see B1193-00 as a hard error code that cannot be clear.
I am planning to remove the module, and have it reset or flash with a a programmer, but i want to know if someone has encounter something like and how it was solved... this car is petrol 3.0 straight 6 engine...
I saw someone has a similar thread here but did not come back to update the forum how he managed to solve that problem
thanks
Rover Range
Texas
The restraints module (SRS) has locked out the fuel pump.
The module will need to be replaced with a new one and reflashed .
wannapreg
Ghana
So could this be the reason why, when I try to command the pump from the ecm or bcm to pressurize the system, no sound is head, even though the fuel pump relay fuse get energize when key is turn on
wannapreg
Ghana
I got the car started, now this was what I did, I got the old RCM removed and got a good srs programmer device go reset the crash data. And then install it the old unit back and then worked on the various points that have permanent fault… that is all..
Mavsdad
