Bad Battery ???
itsaguything
Manotick, On, Canada
Well, we all have our ideas.
I've learned that if there's a question about the battery health, just change it already. In another forum, a smart person came up with ITBS (its the battery, stu...)
And that a maintainer has one thinking the battery is good, when in fact it isn't.
Glad you're up and running!
m_lars
Utah
Sounds like you figured it out, but also battery connections can be an issue as well. Especially in a situation like this where it started fine, then completely quit seeming randomly. It’s cheap and easy to clean a retighten connections before dropping $200+ on a new battery.
Quijote
Metro Boston
Amen. Exactly! ESPECIALLY for LR4's!
neovellian
Colorado
I just over $200 on a new battery and my 2011 5.0L Range Rover still doesn't stay on. Sqitters studders then turns over but immediately dies afterwards? At first I thought automatically it was a fuel issue because it was low so I added a few more gallons and still nothing? Therefore I was pretty sure it was a charging issue and went and got a brand new battery? Still studders and kicks over followed by an immediate shut down? What is going on?
txfromwi
Update and Hopefully Final
Ordered a sheet of 1/32" lead sheet.
Cut to size, trimmed oh so pretty.
Total Time less than 10 minutes.
BUT, too thick.
Pounded out twice more, each time trimming as needed.
Ended about the thickness near that of a sheet of heavy duty aluminium foil.
That fit just fine.
Sorry, did not get out the micrometer...
if you do this I suggest you purchase 1/64" thick lead if available, otherwise just pound it down thinner.
I will keep an eye on it for a while, but I think this one is complete.
Thanks!
Dan
jlglr4
Northern California
My first guess would be a fuel issue, and filling the tank will do nothing towards a diagnosis. You need to get a code reader and look a the codes, preferably one that will also tell you the fuel pressure (both low-pressure fuel side and high pressure at the fuel rail).
mgrovenor
Grand Rapids, Michigan
You need a trickle charger that keeps the battery fresh even after long periods of non-use. Amazon has them for pennies. When you do replace the battery make sure to get an AGM battery so the systems that draw juice while the car sits wont drain it.
ILR4
