Came across an Android Auto / Carplay box with digital audio MOST support
DylanM
Just came across this Android Auto / Apple Carplay addon box for 2012-2016 LR4s that integrates with the factory digital fiber optic MOST network:
This is quite different from other aftermarket boxes that run through the analog AUX input, and audio / music quality should be significantly better (as the documentation states it should integrate with the factory amp and Meridian DSP).
Anyone have any experience with this?
DylanM
...all the other units I've come across on eBay, Amazon, AliExpress, etc use the internal AUX input for audio (which is analog). This is the only one that I've seen so far that taps into the digital MOST fiber optic network (supporting lossless audio)
MellonRover
Northeast USA
I thought the lvds connection was sufficient. I guess that's a no for me, the one you posted is the only MOST one. Seller does state " could" improve signal quality and reduce delay. So not sure if there's a difference worth 3x $.
Definitely keep us updated if you get one!
powershift
Nevada
Nice find. Seems worth the money if it works and its reliable. The existing audio system is respectable with USB playback and higher bit rates. I did not expect that until I tried the PartyBox 1000 in back with an inverter. It had good bass, but everything else about the factory system surpassed it. Also I can discern a difference between playing Pandora HQ over Bluetooth and USB playback, further evidence that the speakers/amps aren't that bad. I'd like to try FLAC format with that device, could be even better SQ.
mm3846
LI, NY
Oh I like this.
Been using Bluetooth with my IDCORE but I can’t get notifications using it that way.
ILR4
