Camshaft sensor, timing belt or new engine? 2015 LR4 75K
JamesUSMC
USA, NC
I noticed my engine light suddenly came on, but no real appearance of rough running or issues. Then while driving (about 70mph) a few miles down the road, the light started flashing. I pulled it over and limped it back home at 35mph. I have an ODB, so I tested it and a bunch of codes (I think 8) in total were on it.
Most dealt with P0300 - P0305 (Misfire of cylinder 5), etc. There were CAM SHAFT SENSOR codes on it as well. I cleared the codes and let the vehicle rest while I called a few places. I was shocked about an hour later when I started/drove it about 4 miles from my house that whatever was wrong appeared to be "gone".
I parked it in front of the service place (Christian Bros). I started it back up after a few minutes and the rough running/idling engine was suddenly back along with that engine light.
Here's the problem... Christian Bros is telling me they think the timing belt is coming apart and it's not a sensor. Then they also think it may have catastrophic engine damage. I'm not sure, but they said it needed oil and they're making a game plan for me.
IF it's the sensor, and it's intermittent - wouldn't I want to check/replace that first? Other thoughts????
avslash
The Lone Star State
More info needed.
First, it doesn't have a timing belt. It has one timing chain for each bank of cylinders. You don't mention the year of your vehicle, but there are known issues with the earlier LR4.
It is not totally a spontaneous failure. Have you had any previous indicators? Most notable would be a rythmic knock from the engine compartment.
Next question would be what are they basing their catastrophic claim on? Low compression? Water mixed with coolant?
It could be a damaged engine. It could also be a bad sensor, bad coil, bad injector, etc, etc.
Bottom line, you need more info for us to be of use. The specific codes it is throwing would be good start.
Good luck.
ETA:. Just saw you said 2015 in thread title. Should be well past the problematic timing chain issues, assuming oil changed regularly.
Makes me highly doubt "catastrophic" engine damage.
jaamrode
If Christian Brothers told you have a timing belt run far far away. The 3.0 V6 has a timing chain not a belt. The chain may stretch, very uncommon, but it won’t “come apart” unless it breaks in which case the engine won’t run and you have bent valve or much greater problems. The 5.0 and 3.0 engines have been known to have tensioner pullyes wear out and cause the timing to skip a tooth or two.
If the codes are only for cylinder 5, I would be looking at the ignition coil or injector for that cylinder.
jettore
I would definitely find a land rover specific indy shop. If they are saying timing belt go pick it up right away.
JamesUSMC
USA, NC
Thanks everyone! I thought it was strange that when the codes were cleared, that it appeared to run just fine. Had me extremely worried that when I parked it down 4 miles down (after a successful drive) that it started running extremely rough again on start up, and of course the engine light came back on. I'm leaning towards something simple in terms of sensors - especially after reading these responses. Also - I'm not sure if they said "belt" or "chain" - but with 75K miles, I seriously doubt it would be a chain. The fact they said it was low on oil has me a little worried... Thanks again!
I'm afraid I've got some bad news...
The timing chain guides in the 5.0 V8 are known for going bad, causing the chain to stretch and requiring replacement of all of it.
The guides were updated to a new part in 2013, but they still purportedly have problems if people stick to Land Rover's insane 15k oil change intervals.
In 2014, your SCV6 engine came out, but it's essentially a 5.0 V8 with the back two cylinders rendered inoperable. Meaning, it's prone to timing chain guide issues if the oil isn't changed more frequently than LR recommends.
That said, I'd think if yours was a timing chain issue, it wouldn't be intermittent.
mpinco
Colorado
Just a thought but mechanical issues don't appear and disappear. On the other hand electrical issues (sensors) can be intermittent and be sensitive to temperature.
I agree, run away from anyone who can't do basic research to know whether you have a timing chain or belt.
scott schmerge
Charlotte, NC
If I’m not mistaken, you’ll get notified on the cluster if your oil level is a quart down. I’ve never been low, but I think I read that on the manual. The truck has to sit not running for a bit for oil level to register.
JamesUSMC
USA, NC
So, I found out the following... took it to a local shop that specialized in LR's.
This was on the email. "Your vehicle has jumped time. We went out to the parking lot and attempted to crank the vehicle and it would not start. It is very noisy while cranking and through the oil fill cap, you can see the Bank 2 Timing Chain. There is an extreme amount of slack in the chain, coupled with fault codes for misfires on that bank, and camshaft timing error on that bank. All signs point to the fact that this motor has jumped time and will need timing chain replacement." All in, $4100.00 and about 5 days. I guess they have to take the entire front end off, and replace a ton of other things while they're in there. They also said my engine has the "older" LR parts that were replaced in late 2015. I'm getting new/upgraded parts - so I guess that's a bonus... Uggg.
avslash
The Lone Star State
Interesting.
We don't seem to get many reports of timing chain issues on 2013-2016 models. Supposedly the "upgraded" parts hit the assembly line for late 2012 production.
If they are doing a proper job on the chain/tensioner replacement then $4,100.00 is not a bad price. It is an involved job that requires a great deal of parts removal to access the chains.
I'm curious how long you have owned the truck and if you are familiar with what the oil change interval on the vehicle has been?
