Can anyone help me figure out the cylinder order on the 2016 SCV6
lwhittington00
United states
Trying to figure out the cylinder order on my 2016 Range Rover sport hst, getting a misfire on cylinder 4 and 5 and it’s running lean. I swapped the spark plugs and it ran good for 2 days and then it started again so was gonna start moving the coil packs around but I cant seem to confirm the cylinder order, does anyone have any suggestions?
Shaggy
Administrator
From what I've seen on the 3.0 supercharged V6, cylinders 1 to 3 are on the passenger side bank and 4 to 6 are on the driver side, counting front to back, but double check it against a diagram before you start pulling coils. If that's right, 4 and 5 are on the same bank, and with it running lean too I'd be looking for a vacuum leak on that side before blaming the coils. Swapping the cylinder 4 coil with one from the other bank is still a cheap test though. Is it showing lean on just one bank or both?
lwhittington00
United states
Okay I’ve been thinking it was 1-3-5 and 2-4-6, I just can’t seem to find a diagram that I can confirm is right. Anyways I swapped coil 5 and 6 if it’s in the order you referring too which would make sense because it’s still misfiring on cylinder 4. I just found out that the brass fitting molded into the cover head that the coil bolt screws into came out with the screw on the first coil driver side so if that is cylinder 4 I’m guessing that could possibly be causing an issue but it’s not loose or moving around or anything so still stumped on what to try next I was thinking maybe a pcv valve
ILR4
