Asilver
I was driving through the city yesterday and the dreaded check engine light popped on. It's actually the first time during my ownership that it's come on and my stomach sank when I saw that amber glow. It still drove fine and wasn't blinking which tends to mean it's safe to continue driving with, so I dropped off my wife then continued home and pulled the codes with my GAP Tool.
After letting the car sit, the check engine light was gone, but there was still a list of faults that showed up. The only ones related to the engine and which most likely caused the light to come on are P0172 - System too rich (bank 1) and P0175 - System too rich (bank 2).
I really have two overarching questions now:
1. Has anybody run into a situation where both banks are running rich? What would be the first thing to look at when diagnosing? My hope is that it's a sensor or something simple that's triggering both sides of the engine to dump excess fuel, rather then stuck injectors or something like that.
2. After viewing faults, do people typically clear them or keep them logged for future reference?
Below is a list of the other codes which showed up for reference:
Under ABS-Brake Module:
U3003-62 Battery voltage - Algorithm based failure - Signal Compare Failure
BCM-Body Control:
B1B01-87 Key Transponder - Bus Signal/message failure
B1087-86 LIN bus A - Bus signal/message failure - signal is invalid
B112B-83 Steering wheel module - Bus signal/message failure - value of signal protection calculation is incorrect
HVAC-Ventilation:
B1B7B-00 Air Blender Actuator - Rear Left
B1B7D-00 Air distribution actuator - rear
IPC-Instrument Pack:
U2013-08 (2E) Switchpack - General failure information - bus signal/message failure
KVM-Keyless
U201F-31 (68) External receiver - frequency modulation/ pulse width modulation failure - no signal
PBM-Parking Brake:
U3000-16 (20) Control module- General electrical failure - circuit voltage below threshold
RCM-Airbag:
B1A00-16 (2C) Control Module - General electrical failure - circuit voltage below threshold
SASM - Steering Angle:
U0300-55 (6C) Internal Control Module software incompatibility - System programming failure - is not configured
Thank you in advance for any feedback you guys have!
Adam
BCM-Body Control:
HVAC-Ventilation:
KVM-Keyless
PBM-Parking Brake:
RCM-Airbag:
Adam
