Connecting a refrigerator
O
Ofer
I had bought a Refrigerator (Waco, 50L), which I would like to connect on the rear. The 12V accessory connector has power only while the switch is turn ON.
It seem that there are two “bad” alternatives to connect it directly to the Battery.
1. Throw the firewall and all the way under the doors frames.
2. Below the car and try to find a way up throw the rear wing.
Does anyone have better idea or any other tips?
tmiller1
Using the search box in the upper right hand corner, type in the phrase: "ARB Fridge - yey!". This is a thread that dealt with some similar issues, maybe it will help you out...
A
AussieLR3
Hi Ofer,
Question slightly off your thread but is this fridge the CF50 and when you put the fridge in the back of your LR3 can you close the cargo blind?
I just bought a Waeco CF50 yesterday which was on special but don't have my LR3 yet to put it in.
Thanks,
Chris
O
Ofer
Hi Chris,
Yes it is CF50 and although it it a 1 cm higher, there is no problem to close the cargo cover
davidsussex
