Defender Lift Kit 33" tires
Johnson Rods
Shown below is a dealer installed Johnson Rod 1.5 inch lift kit with 275-60-20 BFG KO2 (33 inch) tires.
Many Land Rover dealers use our lift in their showrooms as an upgrade package. Our lift is preferred because of the quality of construction and materials that can stand up to extreme hot and cold conditions without breaking down. We use 3/16 high quality stainless steel which provides strength and durability. Our rubber attachment points are extra thick just like the original Land Rover part which insures a tight non slip connection and which makes them less susceptible to cracking and breaking down under harsh conditions. In fact, the rubber is military spec, high tensile strength and operates effectively in temperatures between -60 degrees F to 180 degrees F.
Follow us on Instagram : @johnsonrods
or visit our website: johnsonrods.com
Johnson Rods
275-60-20 Nitto Ridge Grapplers with 1.5 inch Johnson Rod lift
Johnson Rods
265-60-20 (32.5) BFG KO2 tires with 1.5 inch Johnson Rod lift
Johnson Rods
285-45-22 Nitto Ridge Grapplers with 1.5 inch Johnson Rod lift
Johnson Rods
275-60-20 BFG KO2's with 1.5 inch Johnson Rod lift
Dealer installed. Ask your Land Rover dealer to install Johnson Rods.
LB Bill
California
The rods and the tires I could afford- the Defender?..well that's another matter. And who's gonna want to bang up those 22" wheels?
(or a $90-100K 'leased' vehicle for that matter?)
Motoprophet
