scapistron
None of us want to do this test for fear of it being positive, but it is the right thing to do.I would suggest doing a cheap exhaust gas test on the coolant tank. I so wish I would have done that first.
Depends on why the coolant is leaking in the engine area... I know of 2 scenarios: 1. The Y-pipe, Crossover pipe, or other hoses and connections failed purely because they got brittle and cracked due to heat cycles, or 2. the head gasket has failed and created too much pressure for the plastic parts and rubber gaskets in the cooling system to handle and they fail. In my case, it was the latter... I just wasted so much time and money thinking it was the former. Both scenarios will fail the pressure test, but you don't want to spend a bunch of money fixing scenario 1, only to find out you are really dealing with scenario 2.Would a head gasket issue lead to coolant smell at the front? I'll probably start with the pressure test, because I suspect that's the issue given the smell. If that comes out negative, I'll do the combustion gas test.
FWIW, I bought the pressure tester tool from HF as well.. Had to return it because it was so poorly made and would not maintain a seal. I ended up renting one from O'reilly auto parts that had metal adapters.Not scared, I appreciate the detailed answer, it makes a lot of sense. The coolant pipes are all relatively fresh, only 3 years old and 25k miles and I have not seen any coolant leaks. Just the coolant low warning and the smell after struggling up that hill. Looks like HF have both the tool for testing for carbon in the coolant, as well as the pressure tester with an LR-compatible cap.
Where did your replacement come from?this is my second engine. I replaced it about 50k miles ago
