Good evening All,
My 06 LR3 HSE engine light came on and I ran a diagnostic test and the following code displayed with message.
- P0116 (Engine Coolant Temp, Circuit Range/Performance)
I read up on the error and it mentioned that it could be stemming from a bad coolant sensor, so I replaced the ECU sensor, reset the error and after about 20 minutes the engine light was back on.had the error reset. I noticed that there had be a clicking noise that would start when I started the vehicle, but the noise would fade after about 15-20 minutes. I had the service guy at LandRover take a look at it and he noticed that when he disconnected the wire from the fan clutch that the clicking would stop. Once it was reconnected he then noticed that he could stop the fan from spinning by just placing his finger on this with little pressure thought then that the cause was from needing to have the clutch fan replaced because it wasn't properly cooling the engine.
It was recommended that I have the fan clutch replaced and that it was more than likely the reason for the engine light being on. I had the unit replaced yesterday and thought all was good until about the 10th restart...the engine light was back.
I am going to have another diagnostic done to confirm whether or not the same P0116 code is showing up.
Is anyone familiar with this issue?
V/r,
Beazy
V/r,
Beazy
