Help 96 Disco Whole Right Side Leaning
D
davylaw
The Right Side Of My Discovery is leaning do I need to change springs or springs and shocks please let my know thanks
R
RoverDisco98
Same problem with my 98. Comments I've got say the stock springs will sag over time. I was going to upgrade the shocks now L'll do both shocks and springs.
T
tkcomp
How many miles do you have on your 96 disco? Has this happened all of the sudden? (Spring or shock possably broken) or Has it gotten gradually worse over time?
D
discomike
Are you running factory springs and shock? How many miles on your truck? How much of a lean do you have, measure with a tape measure at the wheel wells?
Most likely if you are still stock, you will need to replace both the shocks and springs with something like OME's.
Mike J.
D
discomike
You will be looking at a new set of shocks and springs for sure with that mileage. Take a look at this web site, scan dowm the OME and do some reading, this will answer many questions for you.
http://www.expeditionexchange.com/
Good luck,
Mike J.
ColeCam
Am I crazy or aren't the right side springs supposed to be a little shorter on rovers?
D
discomike
They are the same height, the load rating is different to balance out the weight of the driver. Some shops, like Expedition Exchange will split them up so you can have 2 drivers or passangers side in front if you want. Mine sits level with the normal set up.
Mike J.
D
discomike
You don't need to use the isolaters to level it out. You either put the spring on the way they are tagged or get John to sell you a matched set, talk to him about that.
Mike J.
philfeal
