How-To DIY: Replacing LR4 fuel system low pressure sensor
gsxr
Big Sky Country
While chasing a fuel system problem (details in this thread), one of the possible solutions was a faulty low-pressure sensor in the fuel supply pipes from the tank to the engine. Since a new sensor was ~$40 it seemed like it was worth a shot before dropping the fuel tank, which apparently definitely isn't fun.
The low-pressure sensor is JLR part number LR015356. This is spendy at the dealer, $138 MSRP, online discount dealers have it for around $120 (sample here). There's an aftermarket sensor which is allegedly OEM for much less, under $40, click here to see it at FCP Euro. I bought it from FCP for $38 (naturally, the price dropped to $30 a few days later). It is made in Mexico and appears it might actually be OEM JLR / FoMoCo. Buying the sensor was the end of the easy part.
First up is locating the stupid thing. The FSM (PDF page #4244) says "The fuel LP sensor is installed in a manifold in the fuel supply line. The manifold is located in the rear of the front Right Hand (RH) wheelarch, behind the splash shield." Yeah, nope... it's not anywhere near the wheelarch. This video about the AJ133 fuel system shows a photo at 2:45 which isn't very helpful, and does not match my 2010 LR4. Maybe that photo is from a Range Rover. The text description is accurate though, it is at the right side of the transmission behind a heatshield which is not shown in this photo:
Photos attached below show what it looks like on the 2010 LR4, and probably all LR4 with V8 engine. There's not even space to fit a camera (phone) up there. I briefly considered removing the catalyst pipe but that didn't look easy either.
I removed the smaller top shield first, held on by two 10mm nuts. This exposed the LP sensor, but not the fuel manifold. I thought I could remove the large heat shield to get full view / full access. Nope, can't do that either. After removing most fasteners, I discovered the fuel manifold is attached to a stud ON THE REAR OF THE HEAT SHIELD! It's borderline unpossible to remove the manifold, without risking damage to the plastic fuel pipes, and plastic manifold. Unreal. :mad:
The sensor threads into an adapter pipe which is a quick-connect fitting into the manifold. New OE/Genuine sensors come with the adapter pipe, aftermarket sensors do not. Since there was no way to access the release tabs for the quick-connect fitting, the only option was to unthread the sensor from the adapter pipe. First challenge was removing the electrical connector, I could not press hard enough with my fingers to release it. I used an extra-long screwdriver to press the release tab and then push the connector up & off the sensor.
Now you have to find space to fit tools up there. The adapter tube has 13mm flats so a stubby 13mm wrench can fit. The sensor has ~24mm hex flats, all I could fit up there was a small Crescent (adjustable) wrench. This is the worst part, trying to hold tools in place with no space for your hands, and no room to move.
Once the sensor breaks loose (maybe 1/16 turn) it easily spins out by hand. I was expecting a fuel bath, but not one drop of gasoline was spilled. Odd, but a pleasant surprise. :D Spinning the new sensor in place was uneventful, then it was back to swearing at the tools and lack of space to tighten it. Thankfully after starting the engine there were no apparent leaks. Unfortunately after all this effort, the problem I was trying to remedy remained unsolved... engine still dies 3-4 minutes after a cold start.
Equally frustrating is the lack of data from this sensor. GAP IID does not show pressure readings from it, nor voltage readings. There is NO way to tap into the wiring for voltage checks. There's also no (reasonably easy) way to connect a manual fuel pressure gauge to the low pressure system. I'm sure this was for cost savings, but c'mon... software is effectively free. Why not let the ECM provide readings from this sensor, to diaganostic tools?
Anyway, perhaps this will help the next poor soul who needs to replace this sensor.
(Forum configuration limits to 5 attachments per post... why? :rolleyes: I'll add the rest of the pictures to separate posts below.)
gsxr
Big Sky Country
Next 5 photos show disconnecting the electrical connection and unthreading the sensor from the adapter pipe.
gsxr
Big Sky Country
Photos of the new aftermarket "OEM" sensor from FCP.
And, a screenshot from MicroCat showing the sensor & fuel manifold in the parts diagram.
Longtrail
Ann Arbor
Thanks for sharing this, having just done my transmission pan I know how tight it is up there. Well done.
rubbndubbn
Wisconsin
Thank you for this write up. I had replaced the fuel sensor on the rail on the RH side of the engine but didn't know about this one. Neither has fixed my issue and I am currently stumped on where to go next as I really don't want to keep throwing parts at the LR. Seems to be a fair amount of fuel related issues on this forum currently.
I should add that I removed the lower inner fender plastics on the RH wheel and was able to access this sensor with both hands easier. One going up where the heat shields were removed (I went ahead and removed both of them) and one hand reaching in from the wheel. This made a big difference for me. Just for anyone else trying to tackle this job. Also a deep well socket is needed as a short socket hit the connector.
powershift
Nevada
If the fuel line was empty because you worked on it after it died, then that could mean the fuel pump, something in the tank or something that is part of the fuel line between that sensor and the tank is mucked.
rubbndubbn
Wisconsin
Doesn’t look like you posted before. What is the issue you are trying to solve?
Its a long story so Ill do my best to keep it short...
Went out one day to start the LR4 and it started as it should idles at 1200 then downshift to about 800rpms and then starts to shutter and stalls out. Start it up again does the same sequence. 1200 rpms shifts down and stalls out. Always on the third start it starts again at 1200 and then shifts to 800 and idles out and I can drive the car as intended. However I get a CEL and performance reduced. I can drive about a mile or two and the performance reduced goes away. I can then turn the car off and back on and I have all my power back but still have the CEL.
Codes have ranged from
Fuel pressure at the rail low
Fuel pressure at the rail high
Misfire on all 8 cylinders
random misfire detected
I am unable to clear codes with GAP. It says clearing failed and all codes return.
I have replaced both sensors and no change. Actually when I replaced the upper fuel sensor I got more codes (misfire on all cylinders). I put the old sensor back in and only get a code for Fuel rail pressure high. On the GAP it says desired fuel rail pressure is 10,000kpa but Im usually sitting at about 15,000 kpa. Have also done the AC/Fuel pump relay switch with no change.
To add to this just yesterday my voltage was sitting at 15.0V which seems high for my car usually my high is 14.7V. Im wondering if my battery isnt starting to go out now as well. Going to check that tomorrow.
Attached photos of above mentioned issues.
gsxr
Big Sky Country
15V is abnormally high voltage. If the alternator is original, the regulator might be on the way out? Use an accurate meter to verify the displayed voltage is correct.
rubbndubbn
Wisconsin
Its funny you say that because on the Facebook groups I had mentioned this and they all said 15V isn't that bad and probably just running multiple things in the car and it was cold out. When I saw it I was on the same thoughts as you. Checked battery last night after sitting for 24 hours and was 12.26 so dont think my battery is an issue. Going to check alternator next.
Honby44
