More Voltage fun!
Jimmy Brooks
Pasadena California
Hey all, I am dealing with another voltage issue. Today I noticed that when the truck is on, the voltage is showing 12.58. When the truck is off, the battery reads 12.4. Both of these readings were taken with a multimeter at the battery. No faults; the alternator was replaced 2 years ago with a Denso unit, and I've had no issues until now. The alternator is still communicating with the car and is claiming it's at 35% load at idle; voltage does not change with RPM.
It rained pretty hard here the past couple of days, and I am missing the splash guard on the left side of the car that covers the little access port to the AC compressor, so when I go through a puddle, I sometimes hear the belt squeal. If anyone has an idea of what I should check to figure this out, please reach out; I would love some input.
ftillier
Supporting Member
Supporting Member
Portland, OR, USA
Is there something that leads you to believe there's a problem? Or just the voltages seem low? Do you have the IIDTool to monitor while driving around on a longer trip?
itsaguything
Manotick, On, Canada
Revs of engine do not necessarily affect output voltage of the generator, the ecm is responsible for metering the voltage, based on demand. AGM and lead-acid have different charging demands. 12.4 is not “horrible”. But it may be an indication of the beginning of a failing battery.
powershift
Nevada
I agree higher RPM's don't seem to increase voltage. I tested that the other day idle vs 2k RPM, was surprised. Maybe the alternator outputs full power at idle or the battery simply didn't need more juice at the time I tested it.
12.58V while running is definitely a problem. Could be the voltage regulator inside the alternator. You could try removing the positive off the battery while its running and measure for voltage from the cable to isolate the battery being wonky, but put the cable back on the battery before turning off for a graceful shutdown.
Jimmy Brooks
Pasadena California
I did some digging, decided to unplug the bms to see if the alternator was even capable of putting out 14 volts. Volts went up to 14 when I did that. When I plugged it back in they stayed there and the car has been fine since then… definitely weird but if it stays normal then I’m not complaining.
Jimmy Brooks
Pasadena California
Had an electrical gremlin a couple of years ago that had to do with the ground strap to the engine having resistance and would make the truck reluctant to start but run fine. It would sometimes cause my voltage to sit around 12 while driving and discharge the battery so I thought this was another issue similar coming to haunt me. Since I fixed that issue I’ve never seen the voltage sit below 13.5 so I assumed with a normal functioning electrical system on a 10-13 LR it should always be between 13.5-14.5. Obviously a little bit off of that is ok but I think 12.5v while driving is certainly irregular.
f1racer328
AZ
Turn on your heated seats, and heated windshield/rear defrost and you'll probably see a big voltage change. During that or after you shut everything off the alternator should start charging the battery at a higher voltage.
I have an EcoFlow Alternator charger on my LR4 and the alternator is frustrating to deal with because it'll let the voltage drop as it deems the battery is "full".
Jimmy Brooks
Pasadena California
If I turn on the heated windshield it drops to 12.7, but ive known about that. Nothing else drops it.
ILR4
