CONCH
So I had a CEL light with code P0420-00 (Catalyst System below efficiency threshold bank 1) pop up in early June. Cleared the codes and ran some fuel & CAT cleaner thru for a couple tank fulls. CEL/Code popped again about 3 was later. Cleared again and took a look with the GAP iiD. Tried monitoring the O2 sensors (pic). The iiD only shows a sensor 1 and sensor 2 for each bank. But review of the manual shows there are actually 3 sensors in the LR4 SCV6 exhaust system. So now I'm not sure which 2 were being monitored, and how the third could be listed and/or monitored.
While anything is possible, I'm skeptical that the CAT itself is actually bad at 110K miles. The manual TS'ing does indicate there can be other reasons such as exhaust leakage, misfire (haven't noticed any and it runs very smoothly), oil consumption (hasn't leaked or used any since dealer service about 2K miles ago) or air leaks. There was a reported changing of one O2 sensor by 1st owners service dealer but the records dont indicate which one. My primary question is to try and ascertain which of the two O2 sensors of the 3 the GAP tool is referring to -items 3, 4 or 6 in the EX Diagram. Im thinking 4 & 6 based on the highlighted text, but I could be wrong. Anyone know?
