Mr.BigsLR3
- Joined
- Jul 12, 2009
- Posts
- 313
- Reaction score
- 2
Upon searching every possible LR3 thread about this subject, I cannot understand why you could not add this to a non-locker truck. Here's why:
1. The wiring loom. Folks mentioned that you cannot add it because the wiring is different. Ok, I buy the that. However, why couldn't you simply add the wiring you need with a custom harness and section of wire that is needed?
2. Terrain response computer - Upon adding the wired element, would you not simply need a reflash from a dealer?
3. Mechanicals - the easy part, IMO. Simply drop the open diff and replace with the locking rear diff containing the solenoid.
Land Rover Mechs, what say you? I am not seeing this to be an impossibility. Simply a little time consuming. Given that I have access to a shop with lifts, etc...I may want to try this.
Bigs
Bigs
