Rear interior overhead cabin light leaks
JotaDe
Hey all, so I have a leak that comes out of the overhead cabin light receptor near the tailgate. I can notice it even after washing the vehicle, a few drops of liquid will come out of the light and drip down. I'd like to nip this in the bud as I'm sure a heavy rainstorm will have a much more concerning leak.
Initially I thought the path to water getting into this light fixture would come from the two rubber tubes connecting the tailgate to the body of the car (seen in the center of the jam of the tailgate when it's wide open), but they look very well sealed and appear dry when I've seen the leak occurring. I also use lawn trimmer line to snake out the sunroof drains each year so I'm pretty confident those aren't the issue.
I suspect maybe the satellite antenna cover could have a compromised gasket and be causing the leak. I will get the special bit needed to remove the fixture and check it out (this thread for reference).
Another thread indicated it could be the rear brake light which uses adhesion and could be compromised, but I don't see how a leak from this could reach the light fixture.
I was curious if anyone else has dealt with this issue and what you've found (especially before I rip off the rear brake light)?
JotaDe
Looking at this video, and I think I should double check the two rubber tube connectors again. This guy has the back area disassembled and it does look like those tubes could leak right into the area where the water is leaking out.
ILR4
