Shut Down while in Motion - Again
txfromwi
Please see below.
I used fuel rail pressure as the reference in all data captures.
Please correct me, but MY interpretation from the previous and the following is that the fuel rail pressure decreases relatively slowly and then it falls off suddenly and the engine turns off.
I do not see any control signals telling the pump to turn off, but I do see signals telling the pump to get to work.
If I am interpreting this correctly the pump is mechanically failing to produce enough pressure and as that pressure decays the computers ask for more but the pump doesn't respond and the engine turns off.
So... new pump.... new pressure sensor...both...
Your thoughts??
Thanks!
Dan
SMorelli
Canada
Before you spend any more money this is an experience I had and the diagnosis is free!
I have a 2015 LR4. It started to stall at low revs predominantly in the cold weather and within 10 mins of the first start of the day. Always as I tried to pull away at a junction or traffic lights.
It threw mainly low fuel pressure codes and the display would often switch to the al terrain page. It always re-started and usually ran all day with no issue.
I looked at everything obvious including the fuel relay (it was clicking in & out) in the fuse board to avoid spending $$$.
The first summer the problem disappeared and reappeared in winter. Once started and stalled it seemed like it would run no problem all day and never stalled at speed.
The following summer it continued to stall with increasing frequency. I had a code for O2 sensors and they were due so changed them. This did not fix the issue.
I put it into a specialist in Jan 2023 (very cold at this time of year in Canada) he said it runs fine and wanted to buy it from me. ($500 for driving it back and for to work for 3 weeks!!!!) It stalled two days later and continued to do so including not even starting until the weather got above -10DEGC.
Frustrated I put it into a garage that I trust and had him change Low pressure fuel pump, low pressure sensor, low pressure pump controller & High pressure/temp sensor.
Still it stalled!!!!!!!!
I changed the fuel cap in case the tank was Vacuuming........still stalled!!
I went back to the workshop manual and reviewed the low-pressure system and the only part I had not replaced was the fuel relay but I could still hear it clicking in and out.
A little further research on relays and I found a source that said never trust that just because its energizing that its good.
I removed the relay and energized it with a 12 battery and measured the resistance across the contacts. Each time i energized it the resistace jumped from 0 Ohms (good) to sometimes 600 Ohms (bad).
Bingo!!!!!! the intermittent failure was dirty/bad contacts on the relay that feeds the low pressure fuel pump controller.
I opened up the relay and confirmed this was the issue and even cleaned them with brake cleaner. I then swapped the relay with the same on that feed the AC blower to test my findings and the problem vanished.
I bought two new relays from LR $35ea and now have my car running like a watch!!
I learned the hard way, I hope this helps you guys. Just swap the relays to test yours, no big deal if the blower doesn't work if it proves the issue.
djkaosone
'11 LR4 HSE LUX 5.0L V8
SoCal
Seems like this is happening only when it's warmed up. I know this may seem out of left field, but try replacing your mega fuse.
Parker Freeland
Denver, CO
I had the exact same symptoms and it turned out to be the low-pressure fuel pump and module. $2400 here in Denver.
txfromwi
It's not diagnosed yet, certainly not repaired.
I have a high pressure fuel sensor in hand and based on previous comments here and one note in the mechanics manual that says random stalling can be caused by that sensor, I will replace it and see how it goes.
Thanks everyone!
ILR4
