stuttering and speedometer troubles
D
djbensonchad
I have a 99 discovery and after a dealer oil change i noticed that a day later on a cold start the speedometer was not working, nor was the odometer, or trip indicator, and the vehicle was stuttering when the gas pedal was depressed. The car would pick up after a couple of seconds.
eventually both problems went away after the car was driving for a while.
I have also noticed that when the car is warmed up in the morning i don't run into these problems either.
Is it possible that a bad wire or miss-firing plug would cause either or both of these probs? Any help on this would be greatly appreciated.
DiscoFever
I would be driving straight back to the dealership. I could understand if it were just a bit of stuttering. my cold engine runs a bit rough til it warms up also, but the question is why arent your gauges working...let the dealership undo whatever they did
T
tirewall
Stuttering/Speedometer
Just had a Speedometer/Stutter problem with my '97 Disco. Turns out it was the Vehicle Speed Sensor (Speedometer Transducer). It is located in the transfer case and is accessed from under the vehicle. 5mm allen wrench bolt holds it in. I bought my replacement from www.atlanticbritish.com and it took about 20 minutes start to finish to change. Good Luck,
Tirewall
D
djbensonchad
Thanks guys, although the problem has gone away, i have a new Tranducer and will be installing it this weekend.
I
iggywanna
K OK Then I have a question i have been reeding to see and this is about the closest i have come to my problem.First 96 d1 176k . My d1 seems to shutter on the highway after about 20 miles at high spees like i am loosing power then it fine then a few minutes later it happens again and abck and forth eventually it goes away and it has been doing this for a while. Any suggestions?
THanks
Erich
[email protected]
iggywanna
VSS is either going bad, or you need to change fuel filter or possible the fuel pump...
emmaslovelys
