Suspension Fault - Can I drive???
Johnnycakes
Cleveland
48K miles 2016 HSE. First time seeing the suspension fault error. I'm stuck in ride height (the middle height). Took it to my indy shop, needs a new air compressor. I'm under extended warranty, so it will be covered. Hopefully sometime next week.
As I was driving home from indy shop, the yellow light went to a red light and warned not to exceed 30mph.
Am I ok to drive until next week? Should I watch my speed?
Thanks!
Rover Range
Texas
If the vehicle is at the normal ride height, you can keep driving it.
The red light warning is for people that expect the vehicle to react normally, even though there is an issue with the suspension.
djkaosone
'11 LR4 HSE LUX 5.0L V8
SoCal
You can still drive over 65 mph when it shows the 30 mph warning. Technically not advisable, but doable it it doesn't limit you.
Daveykid
Supporting Member
Supporting Member
Chicago
Thanks!
This guy does a 1,300 mile road trip with a suspension fault and the RR stuck in the high setting. No issues whatsoever so long as you understand you now have a higher COG than in the normal setting.
hang729
New York
If you keep driving for long, at some point will it trigger the “restricted performance” light which is going to be a nightmare?
cnotes628
