Tips on changing Coolant Temp Sensor?
P
pfb
'94 Disco 3.9 V8i.
In an effort to rectify ongoing cold-start problems, I'd like to change the coolant temp sensor.
I haven't even located it under the hood yet. Any tips on changing it out?
Thanks!
RoverChic
I love Ryan and Rovers
Pretty cut and dry. If you search D-Web I posted a picture awhile back where it is located (near the top rad hose). Pull the sensor off and replace. HTH
Sergei
Answer is - easy. Its right next to distributor.
Drawback - to get easy access you need to remove distributor cap, and most likely - pull out coolant upper hoose, and remove housing for thermostat...
while at it
pony up about 50$ and replace ignition modulator :) Its on back of distributor - pain in **** to get there next time. Also may replace thermostat - its about time if never been done.
Nothing else from top of me head..
also - keep handy some kind of gasket solution..
And - chances of cold start problems really be b/c of coolant temp sensor are pretty damn slim
P
pfb
My parts manager at the dealer mentioned that they do sometimes fail (and that the fuel temp sensor rarely if ever fails.
Looking at a web site to help diagnose a possible fuel ECU failure (http://www.carelect.demon.co.uk/rr396.html) I ran across a checklist suggesting to always replace that sensor before taking more drastic measures, and for the $13 bucks it cost me, figuried a good bet.
So now I've located the temp sensor. I see the idle control valve discussd in the service manual, but where is the "stepper motor"?
Sergei
Well think of this - it is starting. It is cold. Only way cold temp sensor can send failing value - is if all the sudden has resistance dropped. However metals, when oxydating or after repeated heat/cold cycles normally would actually gain increased resistance.
Plus on cold start - ECU shouldnt give a monkey bum about values from there. It will play role when things are getting warm. Then again - if you feel like changing it - its your pain :)
Stepper motor is IAC - on your truck its on left hand side, at the rear of plenum. ********* wire bunch comes off the end of it.
Win Ko
