No power to the air suspension compressor
joko supriyono
Folks..
I have problems with my LR3 TDV6 2.4L 2006. The message is "Air suspension Fault". I checked the fuse is ok. Check the coil relay also in good state.
Checked the voltage going to the compressor coil (two wire 2.5 mm2), the voltage is 0 Volt. Of course I checked it with the engine running.
Please advice.
Cheers,
Jack
MArsel
