Removing Full-Length Roof Rails
Hello Everyone,
I have the black design package on my 2013 LR4 and was wondering if I removed the full-length roof rails would I need the rubber trim to cover up the tracks? I am asking because I may actually be switching roof racks (will talk about that later) and may want to remove the full-length roof rails.
Or, I am wondering if the rear part of the full-length rails are the same as the half rails? I am thinking I may be able to keep the rear part of my full-length rails and cut the front off.
Thanks so much!
Regards, David
michal
You may need it.... R u getting the Baja Rack??
michal
Baja - better mounting options. Real expedition roof rack
Did Pedram tell you I was looking at yours really close? ;-)
I've seen others and always liked the look, but the Urban Offroad rack is made really well.
With that said, I just like the height and design of the Baja - mine is closer to the glass and I like how the Baja is set up.
My issue is that I have the black design pack and it came with full length roof rails. The Baja has an option for mounting with half rails (what you have) or no rails. If I remove my full length rails then the back tracks are empty - but just not sure if that's OK.
Maybe I need to just cut my full length to preserve the back racks, just not sure it they are the same.
I am almost billing to bet Pedram could figure something out.
michal
Yep - Pedram told me that you were inspecting my rack :) You will need the rubber rail covers but only for the front part (around the moonroof that opens. Otherwise you should be ok. This shouldn't stop you from getting Baja
I have the rubber rail covers on the front of the rails, but the rails in the back don't seem to have them... They were removed during install.
I am pretty sure the half-rails and the rear of the full-rails are the same tracks, so I am thinking I may just cut off the front of my full rails and call it a day.
I looked up the cross rails and the same ones fit the half or full rails, so I should be fine.
TeriM
