Go Back   Land Rover and Range Rover Forums > Technical Discussions > LR3
Sponsored Ads
Register or log in to remove these ads.
LR3 technical discussions for the LR3
Reply
Thread Tools
Old 05-13-2010, 07:37 PM   #1
mayday247
Roverito
Being in Access Mode for extended periods?
Are there any issues to be aware of when leaving my 2005 LR3 SE in "Access" mode for extended periods of time? Like overnight or for a couple of weeks when I travel? I've got several inches of clearance (at best) in my parking garage and the low ceiling has lots of pipes and sprinkler heads to make coming and going even sketchier. One of my neighbors has already sheared off a sprinkler head with his truck, so to be safe I lower into Access mode when I park every night. Now I'm wondering if I should raise it back to "Normal" mode before I turn her off since I do this everyday?
I haven't had any problems as of late (knock on wood!), but did have to have my air suspension compressor replaced a couple of years back. Also, it sometimes feels that my car is not completely level...like the front right or left is dipping compared to the rest of the car or the whole front end is nosing down compared to the back? I have no idea how it works so figured I'd ask in case I was doing something stupid that I shouldn't. Also, my warranty is up so I want to make sure that I'm taking care of my LR3 as best as possible.
Thanks in advance for any insight on the matter!
mayday247 is offline   Reply With Quote
Old 05-13-2010, 07:43 PM   #2
umbertob's Avatar
That should create no issues, other than your compressor having to work a bit harder in the morning to lift you back up to normal height when you leave the garage. Regarding the car not appearing to be completely level, first make sure it is parked on a level surface of course. If it is, and the distance between the edge of the fender and the wheels seems to be different after the car has had a chance to "self level", get your dealer (or an independent shop equipped with the proper diagnostics) to check your suspensions calibration. It may be off and require a software adjustment.
umbertob is online now   Reply With Quote
Old 05-13-2010, 07:55 PM   #3
blackforestham
blackforestham's Avatar
Also, remember to use the Access Mode lock feature to ensure the vehicle doesn't "self-level" and raise itself into a pipe or worse.
blackforestham is offline   Reply With Quote
Old 05-13-2010, 08:05 PM   #4
umbertob's Avatar
That shouldn't happen, whether you lock Access Height or not. In my experience, whenever the vehicle self levels while unattended it always lowers the corner(s) that require it to match the remaining ones - thus, the farts - all the way down to the bump stops if there is a leak in the system... It should not adjust "up", only down.
Old 05-13-2010, 09:11 PM   #5
Trynian
Only thing that has happened to mine is I slept in it on a camping trip in acess height with the wheels on slightly uneven terrain. At first start up in the morning a suspension fault popped up and said standard height only available. Turned it off and restarted and it was never to be seen again.
In my garage it has never had any issue for days in access height.
__________________
2006 LR3
Trynian is offline   Reply With Quote
Old 05-14-2010, 07:04 AM   #6
CMGRover
I've parked mine in access height many a time to wash it. It doesn't move.
__________________
CMGRover is offline   Reply With Quote
Old 05-14-2010, 09:07 AM   #7
gtc
We park in access height just about every single day (sometimes multiple times - easier to get the kids in & out, nevermind ourselves!), and leave it in access mode at the airport for two weeks at a time several times a year. Have yet to have a single problem...
__________________
06 LR3 SE7
05 Mini Cooper S (sold)
01 BMW 330Ci
Looking: 05/06 BMW M3
gtc is offline   Reply With Quote
Old 05-14-2010, 11:21 AM   #8
umbertob's Avatar
Quote:
Originally Posted by Trynian View Post
I slept in it on a camping trip in acess height... a suspension fault popped up
Wow Scott! You don't look that fat in person.
Old 05-14-2010, 03:32 PM   #9
Trynian
Quote:
That is because I wear loose clothing.
__________________
2006 LR3
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Sponsor Ads
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
Fully Driven Auto Network
GM Truck Forum
Chevy Tahoe Forum
Dodge Ram Forum
Chevy Cobalt Forum
Chevy Tahoe Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Ford Raptor Forum
Scion FR-S Forum
Softball Forum
TRD Forum
Central US Mopars
Southeast Mopars
Cadillac CTS Forum
Oklahoma Dodge Ram Club
Softball Forum
