Land Rover World Logo
Register FAQ Members List Calendar Mark Forums Read
Go Back   Land Rover and Range Rover Forums > Articles
Welcome to the Land Rover and Range Rover Forums, an online Land Rover forum community where you can join thousands of other owners from around the world discussing all things related to Land Rovers. To gain full access to Land Rover World you must register for a free account. As a registered member you will be able to:
  • Get advice from thousands of Rover Owners on how to fix and maintain your Land Rover
  • Gain access to our free classifieds marketplace so you can buy, sell, and trade your Land Rover gear.
  • Post you own photos for hundreds of thousands of people to look at a month
All of this and much more is available to you absolutely free when you register for an account, so join our community today!
If you have any problems with the registration process or your account login, please contact contact support.
Reply
Thread Tools
Old 01-09-2006, 03:06 PM   #1
capthook
Posts: n/a
ABS Modulator Removal / Install (TC,HDC,ABS lights on) [D2]
ABS Modulator Removal / Refit
1. Put a cloth under your modulator to absorb fluid spillage
2. Disconnect the (3) Electrical plugs on your modulator
3. Disconnect the (2) abs lines on the black motor looking side (pump side)
4. Disconnect the (4) abs lines on top of the modulator
5. Loosen the 3 nuts securing it to the mount braket
6. Remove the mounting rubbers
REFIT
1. Position mounting rubbers to modulator
2. Position modulator into the mounting braket & tighten bolts to (9 Nm /7lbf)
3. Clean those brake pipe unions
4. Connect the brake pipe unions to the modulator
5. Tighten the 13mm unions to 22nm / 16lbf
6. Connect the multiplugs to modulator
7. Bleed the system
BLEEDING YOUR SYSTEM
1. Do not allow the brake fluid to fall below the 'min' mark on the res.
2. Don't fill it ABOVE the MAX line
3. Check and see if all hose connections are tight, not leaking
4. Fill your res. to the MAX line
5. Attach a bleed line (rubber vac hose) to your bleed screw on the caliper of the pass. side; submerge the free end in a clear container containing brake fluid
6. Apply pressure to the brakes several times, then apply steady pressure.
7. Loosen the bleed screw to allow air / brake fluid to come out. Allow the pedal to come back without helping it.
8. Depress the brake pedal steadily through it's full stroke and allow it to return without your help
9. Repeat until a flow of clean, air free fluid is purged into the container - then while holding the pedal at the end of a downward stroke, tighten the brake caliper screw to 10 Nm 7lbf
10. top off your fluid to the max level
Also, use only new DOT 4 fluid / don't mix brands as they may or may not be compatible. Always ensure the fluid level is between the min/max in the res. to ensure you don't damage your brake system.
Sponsored Links
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
land rover suspension kits | range rover suspension | Yoli Truth
