Thanks guys...here it what I did...
FIRST BUY LOCK ACTUATOR FOR $25.00
!!!!!!!yes $25.00
1. removed panel with flat face crowbar, no clips broken!!!!
2. cut plastic shield on inside of panel where the lock actuator and right below...
3. unscrewed 3 T25 tork screws holding actuator
4. unhooked line to inside door handle and wire harness for auto locks
5. unhooked steel rod from outside door handle by lifting the black plastic that is holding the rod then popping it out with a screw driver...make sure you have good lighting!!!!
6. unscrewed the bottom 10mm screw of the door/window frame, no other screws needed, you are supposed to completelyremove the frame from both side and the window...
This is what I did....I move the actuator down a little from where it was origianlly placed, pulled on the window/door frame up as much as I could without damaging anything, about 2 inches and from the inside of the door I pulled the door frame to give more space where the door frame and actuator meet, took about 15 min of jaming, pulling, shifting the actuator and door/window frame from the inside an eventually squeezed the lock out.....pain in my ass, but easier then taking apart the whole door.....
7. Then suprisingly easy to put the new acutuaor in...squeezed in pretty easy...after that...lined up the acutaor put the t25 screws to hold in place, pushed back the door/window frame and screwed that back in from inside the door, then tightened all screws, did a test and put back the panel....all in all about 30 min, to do it...and the ******** dealer wants $400, so it takes them over 2 hrs...supposedly....thanks for the help guys...
