Does anyone know the weight distribution? F/R %
I cannot find this info anywhere and short of weighing each axle at a weigh scale I don't have an answer. Has anyone weighed their rig to determine a proper weight distribution? Usually reviewers list it in the specs but in this case nada.
jlach993
Fresh Meadows Queens NY
LR4 Ratings
Base Curb Weight 5617
Gross Vehicle Weight 7143
Gross Axel Weight Front 3197
Gross Axel Weight Rear 4090
Tongue Weight 551
Tow Rate 7716
Unbraked Trailer 1653
Gross Total Weight 14859
Honestly i had these figures copy and pasted on my phone for a few years. I’m not sure if they’re valid, nor do i remember which forum i pulled these numbers from. I’m definitely thinking a euro forum though, but the US specs with our engines aren’t too much off from those numbers.
Those are gross weights though.
I recall reading somewhere that we're close to a 50/50 weight distribution, but I'd love to get some scales and measure it myself.
Thinking about doing something like this.
LR4 Ratings
Tongue Weight 551
Tow Rate 7716
These I have but I want the weight distribution on each axle as it sits empty. A perfectly balanced auto is 50/50 while many fwd platforms are more like 60/40. I have always been curious about Land Rovers higher pressure in the rear tires vs the front and am trying to figure out why. I used to have a sticker on the fuel flap door on my LR3 that gave tire pressures loaded and unloaded. The unloaded was 36 psi all the way around IIRC. However I think due to lawyers in the USA they only give the 42 psi rear rating as it assumes the vehicle is fully loaded including a heavy tongue weight.
