2012 US Spec 5.0 Won’t Start
CRYA
Napa Valley
I know nothing but am voting for the simplest explanation, the battery. I know OP had a battery test done and posted the receipt, and mentioned he tried jumping the truck with other vehicles. If this was me seeing those messages, I'd go get a brand new fully juiced battery and connect it in and try that.
Longtrail
Ann Arbor
Excellent - did you get any photos for us to see? These will help others that follow!
M32H32IS
Texas
See the attached pic for Mega Fuse info. There’s many versions/brands available online.
ftillier
Portland, OR, USA
I had done a search online and used the parts.landroverparamus.com site to cross reference this part number LR080537, but they don't list the LR4 as a valid fitment. Thanks for confirming it worked for you!
Rover Range
Texas
Even though it's 400A fuse, they are a " fast blow fuse". It doesn't take much to blow them.
Jump starting the vehicle off backwards can do it too.
Longtrail
Ann Arbor
This is great to know, LR4 won't start with particular symptoms then look at the mega fuse which is part number LR080537 and rated at 400a, a great search that hopefully helps others who stumble on this issue (perhaps us one day!).
