1993 Range Rover Discovery Radio
Fritz
Hi,
My wife's Range Rover has a radio problem as follows:
Initially the station would not change when the tuner was advanced and in fact turning off power to the radio did not shut down the radio. So we pulled the fuse and then re-inserted it thinking that that might re-set the system. Now when power is turned on the dial light comes on, but nobodys home. Nothing happens and turning power off to the radio does nothing. Turning off the ignition does shut down the radio. Any suggestions?
Fritz
Sounds to me like the radio has seen its last days of use... I would recommend buying a new or used radio and replace it.
Vintage99
