1997 key switch wiring
lestro
I boughta 97 se7 that the key switch was out on and was starting with a screwdriver. I want to put in a aftermarket key switch, but I have a question about the wiring. I found the wire that I believe is the acc(first notch), however I have 2 wires that energise in the run position(second notch). My question is can I put both wires under the same lug on the new switch?
