J
JUrban38
Help!! When My gas level gets to a 1/4 of a tank, my Rover stalls. I wait about two min. and it will restart. Will happen almost every 2 miles until I fill up.
Replaced fuel filter, didn't help. Currently in the process of checking the fuel pump, but am not sure how to remove the slip on gas lines. Does the plastic clips in the fittings have to be trurnned a certain direction? I don't want to pull to hard and break the lines. Looks like 2 plastic clips need pushed out to remove the tank seal and pull out the pump?
My thinking is, I must have purchased some bad gas and have contamination in the tank, or there is a small hole in my pickup line thats sucking air when my gas gets low. I 'm hoping there's some type of filter on the fuel pump?
Any help would be greatly apprciated
