2001 Range Rover overheating
LRTECH
Sounds to me like you have an air pocket in the system (just guessing) it could also be many expensive items... but I am leaning toward and air pocket...
You will need to bleed the system.
Park with the front end up hill or parked on a set of ramps.
Fill the coolant system
Turn on the engine, and the heater
run till it gets warm, shut down
Repeat until it will run warm and not require a refill.
you need to also open up the bleeder (looks like a bid plastic phillips head screw on coolant resevoir) when adding coolant. keep it open until it stops spitting out air and only flowing coolant.
