2005 land rover transmission stick
dds142
Hi. Where is the transmission dip stick for a 2005 land rover range rover located. We have looked everywhere and can't find it.
There isn't one, have to check or fill it thru the fill plug on the side of the tranny pan when the engine is running.
How many miles on your truck, when was it last changed?
socalrovershop
must be at a certain temperature to check the fluid or else you WILL underfill it or over fill it.
NhudeST
I suggest you get in contact with a local tech who specializes in Euro vehicles, especially RR's and ask them how many quarts are needed for it. It takes ATF. IF you under fill it, your RR will make a wizzy sound effect to it, so that's something to keep in mind. Good luck man.:bandit:
Disco2TrailEdit4
