2006 Range Rover iPod/Aux. Input
Joe Sharp
Northern California
If you have the 2006 Range Rover HSE Supercharged you already have an aux port! Look at the rear seat AC modual, on it there is a aux port that you can plug an aux jack into. You then need to select the AUX button on the stereo head unit. Press the music note button. Then next to raido and cd option on the screen you can select aux. hope this helps!
Joe Sharp
Northern California
Hi, i wonder if you can help. A friend has just bought a 2006 Vogue with the logic 7 system. I can't believe it doesn't have a simple aux plug. He not bothered about full controll from the head unit but would like to plug his iphone to play his stored music.
From what i've read the modulator seems to be the most cost effective vs sound quality. Can you tell me if you have the logic 7 if not do you know if its still possible and can you get a modulator that plugs into the bottom of the ipod and charges at the same time.
Thanks for any help
:hello:
I have the logic 7 system in my 06 range rover HSE Supercharged it comes stock with an aux port. Its located on the back seat air conditioning control unit. All you need is an AUX chord! Do not waste your money installing anything!
crossflow
Bedford
I can recommend this...
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/123096009292
I have the 06 vogue with no aux button or input. This guy stripped the dash, updated the head unit to give me the aux option and ran out an aux input for £129.99. While I was there I had the Bluetooth updated as well so that it could see my address book when connected via Bluetooth. That was an extra £60. All done in 40 mins. Blasting tunes all the way home from Birmingham today. Well happy.
Hope this helps!
