2006 Range Rover rear camera problem
Colucci43@comca
My 2006 Range Rover rear camera has started showing just a black screen
with warning lettering dispalyed on the center consol screen when set in reverse????
I recently had the navigation dvd upgrade and my 60K service.
Could this be an electronic problem or a bad camera?
Where else could I purchase a new camera?
I checked all fuses are okay......
Any help would be appreciated. Thank You
Welcome to the forum. Just a guess, but I would start looking for a fuse, but probably a camera issue.
rstone
I'm having this same problem too.
I removed the interior wiper motor trim, exposing three 10mm bolts to remove the exterior spolier trim. You can then get to a small phillips screw that holds the camera in its housing. I removed the camera, wiggled the cables, but only a slight bang of the camera turned the feed back on. When I reassembled, it still worked, but then cut back out. So, for me, it's the actual camera itself, which doesn't have any unclippable wires.
If you ended up figuring out your issue, let me know.
Dandavies9
