2007 LR3 front differential ?
bbyer
Alberta
Also make sure you have the updated (larger) Front Diff Breather - LR019450
Visible between radiator and coolant expansion tank
Easy, cheap, 2 minute install
The link below is to a number of files I have done up related to replacing the front differential breather, p/n LR019450 referred to above.
Doing so pretty much eliminates the blown front differential seal concern that leads to no oil and then the usual fuss.
The new does not plug breather uses Gore Tex fabric and costs maybe fifty dollars now and is a clean hands stand up fix. While two minutes would be correct the second time, it took me maybe a half hour, most of that time attempting to convince myself it was that easy.
The rear differential breather is just the usual open hose with the inverted horseshoe and is tied high up to the fuel tank fill piping - that is the old style open pipe breather and does not normally plug.
The files per the link below explain how to do the upgrade.
I note that many of the files have between one and two thousand views - pretty good given it is not Facebook.
The related Technical Service Bulletin is also included within the attached files; it has 1509 views as of this post.
https://www.disco3.co.uk/gallery/thumbnails.php?album=23952
tomasesto
Front diff! and after having the front diff fluid changed the mechanic indicated that there wasn't even the tiniest of fragments in the drained fluid--so for now I feel pretty good about just keeping on moving!! thanks for all input!!
Dittos Upgraded front breather And Dif oil done couple years back Humming eased and now just a bit louder and still runs great thus Far. Prolly My Time for new oils for both and even tranny filter swap thingy
helge
