2008 RR Lux Pkg - Front Passenger Door Issues
gator944
Hi, Everyone. Hope you guys can help with this.
Symptoms: When locking with remote or button, the door plunger started to drag slowly like it was sticking or had reduced power. At times, it didn't lock at all. After a couple of months, it quit locking all together.
Work Performed: I installed a new door lock actuator with no change.
After installing the new actuator with no benefit, I noticed the following:
  • Auto-down on the window works fine, but window does not go up automatically. I have to hold the switch to put the window up.
  • None of the accent lighting (door pocket/door handle) lights when lights are on.
  • After locking the vehicle with the remote (engaging the alarm) you can open the door without triggering the alarm.
  • When opening the door, no interior lighting comes on like the other three doors.
These symptoms were probably present initially before installing the new actuator. I just didn't notice them because I was so focused on the door lock.
Dandavies9
