3" lift on 95 disco
Vinylland
I'm looking to do a 3" lift on my 95 has anybody used the toddco coil springs, if are they any good, and I was also look for a terriafran 3 lift kit for but I can only find 2"
Havent used either type of spring... but I will say that with a 3 inch lift you will need a lot more than just springs to do the job correctly. Panhard rod will need to be lengthened and the entire drive line will need adjusted to prevent major issue.
Vinylland
I was aware of the angles that would need to be fit just looking for a good lift
In that case, buy the 2 inch and get a 1 inch spacer... :) save some money.
The money is the same for both a 2" and 3" lift. What sort of wheeling are you doing. how big a tire are you wanting to run?
The 2 better lifts are from RTE and OME, both have been around for years and are well proven compared to many of the newer cheaper lifts which are showing up.
Vinylland
I usally go to the pine barrens but looking to go to different places around the east coast, min 33" tire
wolf
There is another issue that evryone who does a lift to facilitate larger tires overlooks - i.e., you will lose some low-end torque owing to the increased wheel size; Toddco actually sells gears for your transfre case to bring that gear ratio back into line for your new and larger tires.
