TrinidadLR4
It is a dealer part, can get it in person from LR dealer or online. You need a dampener and a bolt. All the info is here, including part numbers. http://australiancar.reviews/_pdfs/SB-10069796-0699.pdf
Don't think it is allowed to post a link here due to copyright issues, but it is indeed out there.
Have you ever wondered where you might find Land Rover information if you were broken down in South Africa?
Ahhh.... I see what you did there. Thanks!
I just replaced my transfer case and diff oils today having read through a few threads on the subject including this one. Thank you all for your input. I used the Royal Purple oils recommended by TLT on one of the threads.
Having noticed that so many people have had difficulty refilling I looked around and found an excellent solution that save a lot of messing around: a garden chemical sprayer. I bought mine from Harbor Freight but they're available at Home Depot and Lowes etc. I did one modification, which was leave off the spray connection and instead attach a length of 10mm OD vinyl tubing to the end of outlet tube for extra reach. The one I bought has a small, locking, tap-like trigger to control the flow. Here it is: http://tinyurl.com/yxwtzjuh. I found it valuable to fill it with water to the quantity specs and mark up each beforehand so I didn't have to guess when I used it.
