Just replaced four 02 sensors truck does start a little easier and it sounds better but it still idles rough, dies and there is backfiring through the carb. Trying to figure out what else might be wrong with this thing? Anyone got any advice?
I am sure you had another post, but mileage and last major tune up? Fuel pressure has been tested? Fuel filter changed?
I would start with a full tune up, check fuel pressure and change fuel filter.
If I were to guess from what you are saying, I would say injectors maybe bad, but can say for sure with out a leak down pressure test.
You might check your injectors for leakage by depressing the test valve on the pass side fuel rail after your truck has been sitting for a few minutes
It looks like a tire valve - have a rag handy in case fuel squirts out.
I'd check it after 5 mins, if it still has press, then turn the key on for 30sec. - wait 20 mins and check again.
If it still has pressure after 20 -- 30 mins, I doubt the problem is the injectors leaking.
I used a tire gauge to check fuel pressure @ idle, (have rag handy), if you're under 30psi, I'd also consider a fuel pump (after you change fuel filter)
If the absence of o2's on your truck (didn't you say it had bolts in it?), got your ECU all whacked, it may take several drive cycles to remap. (If it's fixable).
In the meantime, I'd tune it as Joey said, plugs,wires, air & fuel filters - and put premium fuel in it.
There's other possibilities, but those can come after all this.
luck,greg
Thanxs greg! What do you consider a drive cycle? The plug wire and plugs are new and we double checked them to make sure they were hooked up in the correct firing order. Is there any other sensors that could be causing this and do you think if the injectors were bad it would cause the truck to exhaust this black smoke from te exhaust? How hard is it to replace the injectors if I have too? Any advice you could give me is greatly appreciated!
It's my understanding that the DI ECU is adaptive, meaning it resets it operating parameters (within limits) to what it sees from the sensors.
If the sensor exceeds those limits (your o2's were missing), it will turn on engine lite and the ECU will try ( for several drive cycles (maybe several hundred miles, if it's out far enough) until it accepts the new inputs from the sensors.))
We often encourage re-setting your codes and see if they recur.
Do a search here for "ford injectors" , but I wouldn't replace them until your certain yours are leaking. The stock lucas in these are an excellent design.
Even if they are leaking, they're easy to clean/rebuild.
luck,greg
Thanks Greg my freind should be coming over today with his scanner deal and we should be resetting the codes to see what is wrong with this thing. I'll drop you another note after we do do and let you know what type of codes we come up with.
