a bad u joint?
jonzLWB
so i took my 95 lwb in to fix another o2 sensor and i told the mechanic my situation with the vibration cuz its gottin worse theres slight cherping and when i hit about 30 mph the noise is loud and the vibration is worse until about 75 then it quites down. he hasnt had a chance to look at it but he thinks it might be a bad u joint.?? i havent had the tires rotated and the front right tire is a different brand(three goodyear forteras and one big o tire)coulr this be that simple of a solution?
So, how often do you lube the grease fittings?
How many miles on the truck?
If you haven't stayed on top of greasing your drive shafts, you should replace all the u-joints.
jonzLWB
i havent ive had the truck for 7 months and its my first rover.it has 113500 miles,is replacing all u joints pretty expensive?
Well, if it were u-joints a Perssion 344 will do the job.
May need to get it into a shop and find out for sure.
jonzLWB
the drive shaft busted on me on the freeway this morning so it must have been a real bad u joint..
jonzLWB
yea it was jus me and i had a feelin it was gunna go out and sure enough it did so it left my ass stranded on the freeway for about two hours i got my mechanic lookin at it today so hopfully it aint gunna burn a hole in my wallet.thanks for your concern man i'll keep an update on how its goin
There are places where you can buy good used drive shafts, don't buy a new one from Rover. Let us know what sort of estimate you get cause mechanics love to screw people on these.
Let me know if you want a tele number so you can buy a used one.
  • joey
